Voice recognition
By arashsheikhpoor · Mar 23, 2010in General💬 6 posts👁️ 1,243 views
Posted Mar 23, 2010 · 05:06 UTC#1
Hey guys, I just bought the f700bt and I've been trying to use the voice recognition but it has only worked once...I press the main button under the menu and map, but nothing happens...It only worked the first time I pressed... Is there somewhere where I might have turned of the feature? Also I have the Iphone 3g connected through bluetooth to the unit
Posted Mar 23, 2010 · 20:15 UTC#2
anyone?
Posted Mar 23, 2010 · 20:20 UTC#3
Wait 2.5 minutes after you turn the unit on to make sure it is fully booted before trying to use the VR.
Posted Mar 24, 2010 · 07:43 UTC#4
Ok, I figured it out...Apparently the VR works in certain areas...For instance the map or in one of the sources. It will not work in the main menu... Unfortunately I can't get the voice recognition to call some one by names, I have to say the numbers
Posted Mar 24, 2010 · 15:02 UTC#5
Make sure there are no irregular numbers in your phonebook. Make sure all of the numbers are in the 111-111-1111 format. If not, can mess the whole thing up when trying to use VR for calling. Once you fix it, delete your paired phone from the unit, re-pair, and re-sync your phonebook.
Posted Mar 31, 2010 · 08:32 UTC#6
Well i tried it but It does not work...When I say dial a number(digits), or change to cd it works fine.
