Can you save your wallpapers to the unit?
By Junkhead · Mar 24, 2010in General💬 4 posts👁️ 1,166 views
Posted Mar 24, 2010 · 22:45 UTC#1
Just put a new wallpaper on and it will only take them off the SD card, is there anyway to import them into the internal HD on the system?
Posted Mar 24, 2010 · 23:54 UTC#2
When you select a startup screen from a SD card, it's copied to the internal flash memory. Once it's selected, you can remove the SD card.
Posted Mar 25, 2010 · 18:03 UTC#3
thanks, i was talking about saving multiple wallpapers to it though and then removing the SD card, it seems to only save one(the one your using)
Posted Mar 25, 2010 · 18:23 UTC#4
No. Just keep them on the card and select them from there. Its practically the same thing.
