Integrate with factory amplifier
By Stummer · Apr 02, 2010in General💬 5 posts👁️ 1,202 views
Posted Apr 02, 2010 · 15:11 UTC#1
I hope this isn't anywhere else. I have 2009 Honda Civic si with premium audio system. Can I integrate the X910 into the factory amplifier or do I have to purchase an aftermaket amp?
Posted Apr 02, 2010 · 23:02 UTC#2
You can go with an amp bypass harness or without. Its up to you. Either way will work.
Posted Apr 16, 2010 · 17:49 UTC#3
i personally believe that it is better to use a factory amp than bypassing MOST OF THE TIME.
**DISCLAIMER**
as every car and system is designed differently, this may not be the best solution for every application.
external factory amps usually have more power than an internal aftermarket amp, and most cars that have them usually have more than 4 channels (which is all that the AVIC has internally)
Posted Jul 26, 2010 · 12:35 UTC#4
Thanks for your reply,
I would love to use the factory amp. It is a premium sound system with subwoofer. I guess iam wondering if cutting and splicing is necessary for me to be able to utilize the factory amp.
Posted Jul 26, 2010 · 13:24 UTC#5
Depending on what outputs on the AVIC you use, and what inputs the factory system can accept, you may need to go with one of the many line level converters to get an acceptable sound quality.
I'm not saying it will be perfect, it does add some decrease in quality, but to some it's acceptable.
