How does the Z110 order digital audio or video files on CD/DVD/SD/USB? Or more to the point, how do I get it to keep them in order?
I listen to audio books often in my car, to keep from having to exchange CDs every 74 minutes its much easier to rip the whole thing to mp3 then put it on a media card or something. But obviously its critical that the audio files play all in the correct order.
I have mine named with leading 0's 01 – xxx, 02 – xxx. It seems to work but I had one anomaly. I had one file that was too long (long chapter name) and the Z110 couldn't read it although windows could. I took the SD card out and renamed the file then the Z read it just fine, but it placed it at the end of the list. It was chapter 17 of 38 or so, all which had been listed on the Z110 in proper order using numbers with leading zeros, but when I renamed that one file so it could be read it ended up at the bottom of the list.
There must be some way to predict how it will read/order the files. How do I need to name them to make them sort correctly?
