I got my X710BT installed -- FINALLY -- in my truck. Took the install kit a while to get here, but I'll have it finished up tonight and start with the Dynamat. There are a couple of things I want to do, though, if it's possible. I don't know how much control WinCE has over the audio hardware, but it seems I should be able to do this stuff.
First off, I want to change the "iPOD" designation for the AV1 input to something else. Neither I nor anyone else in the family use one, and I'd just like to change the text to read, for example, "HAM". I want to connect the audio from my ham radio transceiver to AV1 and call it that, not an iPod.
Second... is it possible to have AV1 or AV2 either mix with, or better yet mute and override the selected audio source? I like to keep said ham transceiver on while I'm on the road, but often will go for hours without hearing anything. I'd like to listen to music and still hear the VHF/UHF audio when it's there. I have a squelch signal from the rig I could use if needed
Just trying to get rid of one little external speaker foam-taped to the dash.
