help 2nd gen 32gb ipod touch f900bt running hacked 3.02
By thisguy210 · Apr 08, 2010in Problems/Troubleshooting💬 10 posts👁️ 1,039 views
Posted Apr 08, 2010 · 14:50 UTC#1
Hey guys,
I'm looking for some help here. I have an f900bt unit with hacked 3.02 firmware...Here is my issue: I plug in my 2nd gen 32gb ipod touch via the special ipod cable into the usb port. The ipod says accessory attached when I do this...I then go to the unit and it shows all my songs on there, the ipod wheel and I can scroll threw songs, however no sound plays at all?? I know it's wired correctly sound wise because I have perfect sound via the radio and sd when playing music....Before I upgraded to 3.02, I was having the same exact issues....SOMEONE PLEASE HELP THIS IS FRUSTRATING!
Thank you.
Posted Apr 08, 2010 · 16:16 UTC#2
are you using just a regular usb cable? if that is the case you need to buy a rc adapter that will plug into ur head phone jack of the ipod. connect it to ur av1 out. also make sure that ur av1 out is set to ipod
Posted Apr 09, 2010 · 04:46 UTC#4
HHAHAHA my friends think there funny pretending im clueless to the systems...good one jim and kevin....not going to fly.
Posted Apr 09, 2010 · 05:24 UTC#5
When you go cheap on ebay this is often the result you get. Its a cheap ass Chinese knock off and probably not going to work. Buy the proper cable and it will probably work.
Posted Apr 09, 2010 · 23:19 UTC#6
I have the proper cable and since the 3.02 update I get no sound with my F90 either.... It's not a cable problem for me.
Posted Apr 10, 2010 · 21:51 UTC#7
exactly...the cable shouldnt be the issue...another problem with pioneer...what else is new!
Posted Apr 11, 2010 · 00:09 UTC#8
The cable is the issue when you use the WRONG one however..
Posted Apr 11, 2010 · 02:29 UTC#9
clearly when another person using the proper cable with the same unit..haha thanks buddy
Posted Apr 11, 2010 · 13:30 UTC#10
Are you this much of a twit in real life to people trying to help?
We're saying the cable could be the issue in your case because you showed a low-cost ebay knockoff cable as the example of you using the "correct cable" and while it may or may not work right, it's not the Pioneer cable, so you can't refer to it as such, VBLUE was right on the money.
You've never told us if your issue was fixed, since your other post is "I need an RCA harness" no matter what cable you used, without an RCA input the ipod/iphone will not work since it's not properly wired.
There are simple steps that people installing units are expected to know how to do, and one of them is to read the installation sheet on proper hookup.
The person that posted later saying "I have a cable that worked, then I did an upgrade, then it no longer worked" is not in the same boat.
