Annoying rear view/back up camera behavior
By Chuck88 · Apr 09, 2010in Problems/Troubleshooting💬 8 posts👁️ 1,645 views
Posted Apr 09, 2010 · 15:31 UTC#1
Hi there,
I have a X710BT installed with a rear view camera hooked up for sometime. The video from the camera works just fine whenever I put my car to the [R] gear, except one thing: sometime the video is shown (with the white WARNING line on top) for one second or so, then disappears along with the WARNING line for around 2 seconds (nothing, black screen), then reappears again for good (with the white WARNING line on top) during back up.
This happens in 80% of the time and it is very annoying! :twisted:
Anybody has observed this behavior with their setup?
Many thanks.
Posted Apr 11, 2010 · 02:01 UTC#2
Where do you have the reverse signal wire connected to? It sounds almost like an internittant connection such as a switch not making a solid connection or a ground problem. I hooked up a camera for my daugter in law and had a similar problem with a loose ground connection.
Posted Apr 11, 2010 · 03:04 UTC#3
The reverse wiring should be connected correctly, but like you say, it is possible the the ground wire is making a not-so-good contact because the provided camera ground wire is less than tiny, very very small and fragile.
During normal driving, if I turn ON the rear view camera, it behaves the same, 80% of the time!!
Does your daughter's car got the same behavior?
Thanks.
Posted Apr 13, 2010 · 23:16 UTC#4
It did for a while but I fixed the problem by running a solid ground connection. Today's cars have so much plastic it's hard to find a proper ground when you need one!
Posted Apr 14, 2010 · 01:52 UTC#5
If this is the true problem, I would have to wait it to die before I try to fix it, because with my 4x4, it is a long way to re-route the ground from the rear to the front, dismount the dash then reconnect it :mrgreen: .
Thank you very much for the advise. :)
Posted Apr 17, 2010 · 10:53 UTC#6
Been off line for a while, You don't need to run it all the way forward. Just use a good ground point near the camera, make sure its clean then coat it with some grease or Vaseline to prtotect it from corrosion.
Posted Apr 17, 2010 · 17:29 UTC#7
Thanks Laz for your continue support! :D
I have a Honda Pilot 2005, so I don't know whether it will make a good ground in the rear hayon style of door. There are two contact points from the door hinges, and when closed (obviously), there is one additional contact with the rest of the car via the lock point. You know what I mean?
One way to making sure is to use a multimeter, extend the wires and probe between the front and the rear door. Is this enough?
Posted May 08, 2010 · 09:22 UTC#8
I already had a camera with VW Origo menu - where it worked without a single problem ... and now with the AVIC is a problem, so I can see it on camera ... I will try to get another one and tested. :wink:
