My 910BT will not power up in hot weather. It works perfectly in the morning and evenings, however, in the hot afternoons it will freeze at the boot screen, or it reset on the system startup screen. This leads me to believe the system has some kind of heat protection and is shutting down to protect its self. Is that normal? As anyone else has this problem? If so how can I fix it?
BTW I drive a Black car with a black interior, and I live in El Paso TX, however its not even summber yet, is about 86 degrees, so whats going to happen when the temp gets to 100 or more?
