Z110BT Mic does not work.
By Buddy · Apr 12, 2010in Problems/Troubleshooting💬 20 posts👁️ 4,130 views
Posted Apr 12, 2010 · 00:36 UTC#1
Hi. I recently installed the Z110BT into my trailblazer. Everything works great except the mic does not work at all. I tried it on voice recognition for the IPod, Nav & blutooth for my phone. The `unit says does not recognize, and/or the person on the other end of the phone cant here me. Did I overlook something on the install? or is there a setting I need to go to turn it on or adjust the gain??? I am stumped. I did not completely put back the dash in case I need to pull it back out again in the event the mic is bad. Any advice would be great. Thanks...Buddy
Posted Apr 12, 2010 · 00:49 UTC#2
Probably defective. Replace it.
Posted Apr 12, 2010 · 01:31 UTC#3
Is the mic inserted all the way? Members have had these issues before and it's usually caused by the mic not being in all the way.
Also, check the cable. It might have been pinched somewhere.
Posted Apr 12, 2010 · 05:53 UTC#4
Also make sure you have it plugged in the "mic" hole and not the wired remote input hole
Posted Apr 12, 2010 · 07:45 UTC#5
Thanks, forgot to add that. :D
Posted Apr 13, 2010 · 12:09 UTC#6
Thanks. I will check that connection again. I believe it is, but I will check. I contacted Pioneer and they told me to fax all my documents to them for a replacement. Lets see what happens.
Posted Apr 13, 2010 · 20:05 UTC#7
WOW......... I tried to contact Pioneer directly and got the serious runaround. They said to fax the sales receipt to a fax # that did not work, then gave me another one??? did not reply to e-mails, told me to contact the store where I bought it from, they told me that Pioneer was responsible for a replacement and wanted me to send THE ENTIRE UNIT back to them(I don't think so... its installed).. how hard is it just to get a replacement part??
Anyone have this problem with Pioneer? Their customer service sucks to say the least.
Posted Apr 13, 2010 · 20:49 UTC#8
Yes, that is typical with them. Keep calling till you get a competent person.
Posted Apr 14, 2010 · 17:20 UTC#9
Here's a little "tid bit" Just for kicks, I plugged into the Mic socket on the back of my 110BT an XBox 360 headset with a Mic and IT WORKED!!!. So now I know that the unit comes with a mono jack to accept the included mic will work with a stereo 3.5mm plug. Whats up with that???
In the mean time I ordered a computer Mic with a 3.5mm plug to replace the stock Mic that Pioneer doesn't really care to reply back to me.
Posted Apr 14, 2010 · 17:22 UTC#10
The nerd in me just wants to tell you to use the xbox mic.
Can you imagine rolling up next to someone at a light with THAT mofo strapped to your noggin? Ha! :lol:
Posted Apr 14, 2010 · 18:06 UTC#11
I got to tell you, on a whim I just plugged it in and it worked. And guess what??? Pioneer shot me an email today and said that they were sending me a new Mic. Never thought I would here from them. Now I need to figgure out what wire I need to have the unit auto dim the display at night and where to hook it up.
Posted Apr 14, 2010 · 18:11 UTC#12
The ILL wire (has a tag). Hook it to a wire that sends a pulse when you turn on your headlights. :)
Posted Apr 14, 2010 · 18:15 UTC#13
Ear buds work for testing purposes too :)
Posted Apr 15, 2010 · 20:49 UTC#14
My headlights come on automatically. Still trying to figure this one out. I located the correct wire, now trying to locate what wire sends a "pulse" when the headlight actually do come on.
Posted Apr 15, 2010 · 20:58 UTC#15
Are you using a multimeter?
Posted Apr 15, 2010 · 22:04 UTC#16
no. What is that? and what does it do,
Posted Apr 17, 2010 · 12:58 UTC#17
It's an electrical tool that allows you to measure current, in real time, traveling through a wire.
I have heard that you can tie into the rear wiper switch (?!?) which will control the dimmer/illumination wire. This is a brown wire with a white stripe.
image courtesoy of ss-shoutout.com
Posted Apr 18, 2010 · 04:10 UTC#18
the trailblazer depending on the year may not have a light wire at the radio harness. it may be done thru can bus data. hook the pioneer ill. wire to the ash tray light wire, or a lighted switch near the radio. that will dim it when the auto lights come on or when you turn them on yourself. jim
Posted Apr 18, 2010 · 04:20 UTC#19
Quoted for truth. This is the route I will probably take with my 4Runner since the dash clock dims when the headlights are on. This is good advice, that wiper switch tip freaks me out.
Posted Apr 19, 2010 · 00:22 UTC#20
ok. Got it to work just fine. Its the Brown/White stripe wire in the wiper harness. Works like a champ. Just waiting for the replacement mic and I can close up the dash. Still cant get the thing to sync with my ipod yet. Look into that next. Thanks all for your help and input.
