no sound from f900bt
By DIESEL758 · Apr 16, 2010in Problems/Troubleshooting💬 9 posts👁️ 856 views
Posted Apr 16, 2010 · 00:58 UTC#1
i have the f900bt i just got it and hooked it up but there is no sound from speakers, i do not have the rca harness i bought the unit from a refurb place.
Posted Apr 16, 2010 · 02:42 UTC#2
what kind of car?
Posted Apr 16, 2010 · 03:13 UTC#3
its a 2007 dodge ram 2500
Posted Apr 16, 2010 · 13:47 UTC#4
Anybody have any ideas what it could be, waiting for the rca harness to come in, could the unit be stuck in mute mode
Posted Apr 16, 2010 · 14:18 UTC#5
The obvious questions come to mind, does the vehicle have a built in amp? is that wired properly? that's the usual culprit for no audio at all.
do you trust the installer, etc..
With no RCA header/harness, there's no mute wire, since it's in that harness.
Posted Apr 16, 2010 · 14:31 UTC#6
No amp pretty straight forward setup RADIO/SPEAKERS. I took another pioneer cd player and hooked it up and works fine, i was wondering about the mute wire because the unit is a refurb, could they have placed it in mute and left it.
Posted Apr 16, 2010 · 17:23 UTC#7
NO, it only mutes when the mute wire is grounded, no mute wire, no mute
Posted Apr 16, 2010 · 20:25 UTC#8
So its prob. the internal amp then, this shouldnt effect the rca outputs.
Posted Apr 19, 2010 · 14:30 UTC#9
unless there is a problem with the sound processing part of the unit, if there is a problem with the pre amp then the RCA's probably have the same problem.
