Reason Cruthfield says z110bt will not fit?
By sumwereinsilence · Apr 20, 2010in General💬 6 posts👁️ 1,481 views
Posted Apr 20, 2010 · 02:28 UTC#1
I have a 2004 Alero. I was prevoiously going to get a x920bt until i dug some more and realized with a software update Id be getting a better deal on a z110bt. On my readings tonight i realized some folks were complaining about GM's un-standard stereo sizes, so i decided I better look up to see if the unit would fit and sadly Crutchfield showed that it would not fit, but the Kenwood DNX9960 would. I decided to look up the dimensions of the two units and from what i can tell the kenwood is coming in slightly bigger.
Avic Z110bt
Dimensions (W × H × D):
Chassis: 178mm × 100mm × 165mm (7 in. × 3-7/8 in. × 6-1/2 in.)
Nose: 170mm × 96mm × 17mm (6-3/4 in. × 3-3/4 in. × 5/8 in.)
DNX9960
181.7 x 100 x 180mm (7-3/16 x 3-15/16 x 7-1/8 inches)
The only thing I can think of is the oem alero bezel that goes around the stereo is rounded, but i should be able to mod that. But even then I wouldnt think the Kenwood would fit if the Pioneer doesnt.
Thanks for the help.
Posted Apr 20, 2010 · 03:57 UTC#2
Dont go by what Crutchfield says. I will likely fit without problem. They say the same about my car and I have had every nevi for the last three years.
Posted Apr 20, 2010 · 04:46 UTC#3
As long as your vehicle has a DoubleDIn opening (which yours does) it will fit.
Posted Apr 27, 2010 · 05:20 UTC#4
Check out http://documents.victorytechnologies.com//documents/product/16348.pdf. This is the manual to the kit you would use to give you more of a visual. I hate Crutchfield as their info seems to always be inaccurate. They said my Dub was single din and it clearly is double din with install kits available for it.
Good luck with your install.
Posted May 08, 2010 · 00:55 UTC#5
Keep in mind z110 has a flip down face. So if there is a lip it may not open as it should.
Posted May 08, 2010 · 05:34 UTC#6
I got the unit and am aware of that, but am not really worried I never listen to cds anyways. Im going to try the install monday when its supposed to cool down out here in the desert.
