Yet Another VSS Not Hooked Up!!
By DennisOS2 · Dec 11, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,551 views
Posted Dec 11, 2006 · 04:47 UTC#1
In reading through this forum (thank you, thank you), the manual, and going through the screen on my Z1, I'm pretty certain the installers didn't connect the VSS wire on my '97 Mitsubishi 3000GT VR4. No speed pulse, no 3D Mode, just Simple Hybrid.
I looked on the site that is gives the VSS wire descriptions, but as luck would have it, my car is not listed. Any other sources for this info?
Thanks in advance!
Dennis -==- Philly
Posted Dec 11, 2006 · 06:32 UTC#2
you can always go into the dealership and goto the parts counter for a wiring diagram. there is also the repair manuals you can get in auto parts stores... they have some decent wiring diagrams depending on which guide you get....
Posted Dec 11, 2006 · 12:06 UTC#3
I don't know where it is, but there are a few guys here who have either photographic memories or circuit diagrams for every car. What you should do, if you haven't done it, is post a message in the "Vehicle Specific Wiring" section and the topic should be "VSS wire on '97 Mitsubishi 3000GT VR4?". Someone will tell you where to find it, if they don't stumble up on this post here.
Posted Dec 11, 2006 · 13:37 UTC#4
Your VSS is yellow with a white stripe at the cruise control module in the passenger kick panel. Reverse is red with a blue stripe in the driver's kick, if you need that.
Posted Dec 11, 2006 · 13:46 UTC#5
See I told you there were smart and helpful people on this forum. :)
Posted Dec 11, 2006 · 15:06 UTC#6
Glad to help. I get a lot of info here, so I give back whenever I can.
Posted Apr 19, 2007 · 04:13 UTC#7
I have a 98 3000gt.... I can not firnd a yellow wire with white anywhere in the Passenger kick panel.... where is the VSS!>!>!
Posted Apr 19, 2007 · 12:33 UTC#8
Speed Sense YELLOW (AC) AT ECM BEHIND CENTER CONSOLE, PIN 85
