Issues Please Help
By jayshahu · Apr 22, 2010in Problems/Troubleshooting💬 5 posts👁️ 920 views
Posted Apr 22, 2010 · 07:40 UTC#1
1) I set up my sound settings for the stereo but the high pass filter doesnt like to stay set
so it keeps switching off and I keep having to set it back. I set my low pass sub filter to
80hz so every freq under 80 goes to the subs. High pass set at 80 so everything above 80 goes
to speakers making them sound clearer without the bass stress.
2) plugged in an address and it took me a longer route than it should have.
3) When listening to music, a call comes in through bluetooth, you answer it have a convo, hang
up, and the music never paused so you may be on a completely different song or in a random spot
of the song you were listening too.
4) I can pick up my phone and dial the contact quicker than the voice rec does.
5) Voice Rec library for ipod takes too long when booting up unit.
6) Was using bluetooth audio to listen to pandora which works great, however a call came in and
I had a convo, hung up then all the sudden my ipod was blasting through the speakers! volume
difference from the BTaudio.
7) Put some .avi files on a SDcard for the slot and it only played 2 out of 8. Why?
Posted Apr 22, 2010 · 07:48 UTC#2
1. Dont turn on the sound stage. If you do, it turns off the HPF.
2. Check your route conditions/avoidances.
3. It would be nice but thats the way it works. Been that way sense the last three units.
4. Then do so.
5. Then don't use it.
6. Dont know what to tell ya there. That never happened to me.
7. SD/USB media support is limited so probably a compatibility issues. There are many different forms of .avi and ways to encode them so you cant expect the unit to handle all of them the same way.
Posted Apr 22, 2010 · 07:50 UTC#3
Thanks for the quick reply. Do you ever sleep. :)
Posted Apr 22, 2010 · 07:58 UTC#4
For question 7, make sure the videos are in DivX format. AVI is only the container for the video, containers and codecs are different.
And no, we mods never sleep. :twisted:
Posted Apr 22, 2010 · 07:58 UTC#5
Very rarely.
