2003 f350 diesel vss location
By BP's F-350 superduty · Apr 25, 2010in Vehicle Specific Wiring💬 3 posts👁️ 1,721 views
Posted Apr 25, 2010 · 16:16 UTC#1
I am told it is pin number 68 on the harness. I didn't disconnect anything to find pin numbers, can any one tell me if they are labeled? I don't want to hook up my 910bt to the wrong wire and cause a problem.
Also, is there a good source to show how to do the bypass? Do I still hook up to the emergency break?
Any help would be apprectated, thanks!
BP
Posted Apr 25, 2010 · 17:18 UTC#2
FROM WHAT I HAVE FOUND IT SHOULD BE THE GREY WIRE WITH BLK STRIPE
FOUND THIS ON HERE
http://www.ford-trucks.com/forums/88157 ... .html..ITS ALSO LISTED AS THE SAME WIRE ON THE SUPERDUTY
HOPE IT HELPS
Posted Apr 25, 2010 · 22:07 UTC#3
Thanks, I was just told that by Crutchfield also. There are so many wires there, I am just wondering if there is more than one gray w/ blk stripe wire?? Any ideas? Thanks.
