Will the new map updatedisks install properly if the brake bypass has been applied? Literature has an emphasis placed on setting the parking brake like the install will fail, if you don't do it.
installing upgrade maps with brake bypass
Hi,
Pop them in a go...... There will be no Issues ![]()
I did my upgrade while I was driving and had no problems. My D3 has the bypass installed and I never used my parking brake.
Thanks only I will not do it will driving!!!! I am very confident with computers but when the directions say you cannot go back, and warn of possible problems when installing where there is a brake bypass, I sit up and take notice.
THANKS TO ALL OF YOU WHO'VE LEFT COMMENTS.
I BRAVELY INSERTED A DISC (DID NOT SEEM TO MATTER WHICH ONE) AND SAT BACK WITH A DIET ICE TEA WHILE IT WORKED ITS MAGIC IN JUST A FEW SECONDS. WHEN IT SEEMED OVER AND THE SCREEN HAD SAID :YOU UNIT HAS BEEN UPDATED, OR SOME SUCH MESSAGE, i CHECKED A FEW ADDRESSES JUST FINE, TURN IT OFF AND WENT IN TO COOK SUPPER.
sO THANKS AGAIN.
HOPE THEY LEAVE THE QUESTION UP LONG ENOUGH IT WILL HELP SOMEONE ELSE.
