This is not my first install of the Avic Z2, I had it in my old Trailblazer SS and it worked 100% no issues. I just installed it in my SRT-10 Ram and everything was just as before except for the camera will flash on at will. No ryme or reason it just switches on then back off. I checked all grounds and I even switched the hookup from the radio harness backup sencor to the rear backup light it's self. Still the same issue not sure what it could be. I even tried to use a 1/2 amp diod to keep feedback from turning it on but it was no help.
I curently have the power wire of the camera hooked to an ignition lead and grounded to the frame, this allows the Avic to be able to use the rear view mode while driving.
Any idea what I'm doing wrong?
Thanks,
Mat
