I'm not sure if this is common knowledge or not, but if you flip the white plug over and look at the bottom there are 3 little notches in the bottom. If you pry up on all of them, the center piece that does the locking becomes loose. Don't take it all the way out though!
From there, just take a straightened out staple and put it in the small rectangular hole below the pin you are removing. Give the wire a little tug and it should come right out.
Move the wire over and then snap the center piece of the connector back down into place and you should be good to go.
That should help those who are trying to do the bypass and having a difficult time moving the wire over.
