N2 "oversteer" and map Q's
By Smac61 · May 02, 2010in Problems/Troubleshooting💬 7 posts👁️ 1,842 views
Posted May 02, 2010 · 18:40 UTC#1
Just installed a new to me N2. Its working fairly well however the GPS over steers every corner and takes about 100 yards or so to snap back onto the street I'm on. Is this a common issue? Does it work out after it "learns" the vehicle, or is it just the way it is?
Another question, I have a copy of the 90 maps, is there any risk using these on my unit?
N2 - original software - bypassed - e brake wire grounded - vss and reverse lines hooked up - hide a way flat, properly oriented, and secured to floor under passenger seat with velcro.
Thanks,
Smac
Posted May 10, 2010 · 05:23 UTC#2
I have had problems in the past taking a NAV out of one car and putting it into another but what I have found is that you need to clear everything out of its memory as far as the screen that has a picture of a car with green bars around it. I don't have one in front of me right now but it will clear speed pulses average speed and some other stuff, should be good to go after that.
Posted May 11, 2010 · 00:37 UTC#3
I stumbled across that screen and did exactly that and its been good since.
I guess that confirms what did it...
Thanks,
Sean
Posted May 11, 2010 · 18:21 UTC#4
Could you elaborate on the car with green bars around it. Where did you find that screen? I find that my arrow sometimes does not face in the direction I am traveling.
Posted May 11, 2010 · 20:15 UTC#5
Settings - Hardware info - 3D calibration
Reset all the sensors.
Good luck,
Sean
Posted May 12, 2010 · 22:48 UTC#6
Gave it a shot this afternoon I'll have to see if it works.Thanks for the tip.
tommy t
Posted May 24, 2010 · 10:43 UTC#7
Hey Guys,
The reset seems to have worked. Thanks for the tip.
