IllumiColor issues after 3.02 update (700bt)
By Desrock · May 06, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,408 views
Posted May 06, 2010 · 19:58 UTC#1
Quick question, after my upgrade to 3.002 from Ver 2.006. The issue I am having is after reboot the IllumiColor setting will not stay (it cycles through all). I have set a custom color multiple times and it works while the radio is on, then after reboot the setting is gone. Any ideas?
Also any chance there is a Bluetooth update for the 700bt? (other then the 700bt RC3 from pioneer)
Posted May 07, 2010 · 16:24 UTC#2
You set your color then press custom 1,2,3 to store it. Just press 1 then to try it change the color and go back to the one you set. Should be fine
Posted May 07, 2010 · 18:07 UTC#3
I can set the color that way as many times as I want (have 10+times), after the radio shuts off and reboots. It is back to cycling and the Memory 1,2, or 3 is not saved. Is there a preferences file or something in the "My Flash Drive" folder that i can check (too see if it is there even).
thanks!
Posted Oct 29, 2010 · 14:54 UTC#4
I am now having this same problem with my X910 after I upgraded from v 3.0101 to v 3.0201
Edited Nov 02, 2010 by Newman
