Accessories
By Nebster · Dec 12, 2006in General💬 10 posts👁️ 1,998 views
Posted Dec 12, 2006 · 23:08 UTC#1
Well i just bought a N3. (FINALLY) and i'm looking at getting xm, a backup camera and a ipod adapter. I was wondering will all these fit to the brain or will i have to get a splitter so to speak.
Posted Dec 12, 2006 · 23:16 UTC#2
No it'll all work.
The iPod gets plugged in to the XM and then the XM to the brain (or vice versa) and the rear view camera connects to an RCA at either the brain or the headunit.
Posted Dec 13, 2006 · 03:00 UTC#3
ahh ok i see it now so each accessory has a little "piggy back" function and it can just leach onto itself. if i want to get a rear view camera so i can just watch have it on while driving would i just hook it into the rca or is there something special i need to do with it?
Posted Dec 13, 2006 · 06:07 UTC#4
There is an RCA input for the camera. It will most likely need a power and ground connection too
Posted Dec 13, 2006 · 17:03 UTC#5
ok i guess i just need to get the unit in and play around with it.
Posted Dec 13, 2006 · 18:38 UTC#6
Normally, the camera will be displayed when you put the car in reverse, or if you run your navigation display as a split-screen. If you want full screen reverse camera while driving, put a switch to feed +12v to the nav, but diode-isolate the leads so you don't turn on your reverse lights.
Posted Dec 14, 2006 · 00:44 UTC#7
Why not just power the camera off a switched line then hook the reverse wire up to the avic. In split screen mode even going forward I can still see behind me with the camera.
Posted Dec 14, 2006 · 08:40 UTC#8
If you want the rear camera to display full screen, you need to feed a false trigger to the head unit, so it will display the full size camera image.
Posted Dec 15, 2006 · 02:23 UTC#9
Didn't think about a full screen image. Sorry I'm going to go hide in the corner now.
Posted Dec 15, 2006 · 04:59 UTC#10
hmmm well like i said i'll wait till i have time to get the unit in.
