3.0 Update Nightmare! - HELP NEEDED!
By Ford1 · May 08, 2010in Problems/Troubleshooting💬 2 posts👁️ 705 views
Posted May 08, 2010 · 02:39 UTC#1
I just tried to get my f700bt back up and running by installing 3.0.
But I'm still missing something. I followed the steps as best as I could.
When I got down to copying files off my SD and put them on my system, I got a message that stated that I needed to delete one or more files to finishing copying the files onto the system. Then the Load Library Error came up.
What did I do wrong? Can I get some help with this isue. PM's are welcome, need this back up and running this weekend! HELP! :!:
Posted May 08, 2010 · 13:23 UTC#2
use the 3.0 update from this forum as this erases your drive before installing the 3.0. Make sure that you follow the directions to a 'T'. The reason that you are getting the 'no room' error message is that your previous files are not erased before the new files are added and the system sees it as you are trying to install an item that would exceed its size. The 3.0 update on this site completely formats and erases your drive before installing the new 3.0
