I recently put in the Z110BT into my 2006 charger. Everything seems to be working fine except that whenever I have a BT phone call I hear distortion in the voice coming through the speakers. It is like a buzz accompanying the voice similar to the way a blown speaker will buzz. I get this only at higher volumes so if I turn off the car and use it with the volume low it is fine. It does not seem to matter if the phone BT volume is high or if the Z110BT volume is high. It seems like when the unit amplifies it that it becomes distorted. It happens not only with BT phone calls but also with the NAV prompts and also the voice that prompts me to enter a VR command.
The music and movies audio is great and I hear no such distortions ... only with the voices from BT and NAV.
Anyone else have this or a clue as to any solution? It is making BT unusable if the car is moving.
Thank you.
