Harness Question for someone upgrading AVIC-D2 to X920
By NauticaTom · May 13, 2010in General💬 2 posts👁️ 640 views
Posted May 13, 2010 · 16:35 UTC#1
Hello, I have a question. I am looking to replace my AViC-D2, which is getting a little long in the tooth with a X920. I am curious about 2 things.
1. Does the harness pins match up (Plug and Play Operation?) obviously I will replace the GPS antenna, but rather not go through the whole re-wiring deal.
2. Does the Backup Camera that worked with the D2 work the same for The X920?
Thanks in advance
Tom
Posted May 13, 2010 · 19:22 UTC#2
1. No - you will need to rewire with the X920 harness
2. You should be fine using your existing camera
