Power Supply help needed - F900BT
By costapacket · May 16, 2010in Problems/Troubleshooting💬 2 posts👁️ 863 views
Posted May 16, 2010 · 22:48 UTC#1
I have a F900BT fitted in an Alfa Romeo, when the electronic key is placed in the ignition the unit starts booting up in the normal way, the problem is that when I then start the car (by pressing the stop/start button) the voltage must drop as the unit cuts out then starts to boot up again. I am worried that this constant false starting may cause some problems, does anyone know how I can get around it? Thanks in advance for any help you might be able to give me.
Posted May 17, 2010 · 22:27 UTC#2
I posted a circuit to cure this very problem a year or three back. I don't recall which thread it was in.
