f7010bt boot loop
By orangesuburban · May 17, 2010in Problems/Troubleshooting💬 2 posts👁️ 898 views
Posted May 17, 2010 · 06:00 UTC#1
my friend gave me his f7010 to see if i could fix it for him and im a bit confused. its doing the boot loop that seems to be a common issue. i went into test mode to try and drop in my "my flash disk" from my F90 to see if that would fix it. but i cant delete the flash disk that is on the unit. according to Total Commander there are 68 files = 216gb (wtf?) in the flash disk folder that i cant delete.
suggestions on what to do from here?
Posted May 25, 2010 · 19:51 UTC#2
Go to the service menu reload wince with the format option... then drop your f90bt image on it... use the same version of wince in both places or you will get some weird things happening.
