Can't get N2 out of day mode
By dodgeintrenton · Dec 13, 2006in Problems/Troubleshooting💬 8 posts👁️ 1,617 views
Posted Dec 13, 2006 · 21:11 UTC#1
:x I've had the unit for a while...worked fine until one night it never switched into nighttime display.....double checked the menu option...that was fine....messed with my headlight switch...nothing....the option is displaying nighttime but its in day display...any ideas.
Posted Dec 14, 2006 · 00:38 UTC#2
Check the illumination wire. It might have come disconnected. What kind of car is it in?
Posted Dec 14, 2006 · 01:13 UTC#3
Mine never switches between day/night mode at all, I'm probably going to bring it back to the place where I got it installed and have them look at it.
Posted Dec 15, 2006 · 02:10 UTC#4
It's in a dodge durango. Self installed. The wires are all properly installed and intact along with the connections. It seems like that end is working fine, seeing as how I can manually change the display menu to nighttime but it only stays in daytime mode visually.Sorry....confusing
Posted Dec 15, 2006 · 02:14 UTC#5
What year is the durango? Is the illumination wire from the avic hooked up to the orange or the orange/white wire of the harness?
Posted Dec 16, 2006 · 03:16 UTC#6
It is an 01 slt with the infinity system. I have double and triple checked my connections...like I said I checked the menu option where you can manually change the display to night or day but it wont change....I even went into the menu with the brightness contrast etc.... it's sensing the darkness properly just not changing......wtf....its been fine for months
Posted Dec 16, 2006 · 05:03 UTC#7
Ok so where is the illumination wire of the z1 hooked up to?
Posted Dec 28, 2006 · 23:08 UTC#8
Go to the connections screen and see if the voltage is changing for illumination when you turn on and off your headlights. If it is not, check your wiring. If it is, hold down the WIDE button to go to the screen display settings and check there... If none of those settings fix ya up, try a reset...
