Will my Navigator back up assist work with Z110BT?
By tallpaul42 · May 22, 2010in General💬 6 posts👁️ 797 views
Posted May 22, 2010 · 03:02 UTC#1
I just ordered a Z110BT to replace my factory unit in my 03 Navigator. Am I going to lose my back up assist feature? I guess a nice deck is a trade-off for having to pay better attention to backing up, but I'm hoping that won't be the case. Thanks!
Posted May 26, 2010 · 07:01 UTC#2
So Pioneer says it will, but said it would likely need an adapter of some sort to contact an installer. Neither installer I talked to was much help. Does anybody know? Something PAC makes perhaps?
Posted May 26, 2010 · 15:36 UTC#3
How does the back up assist work on it (I know how back up assists work, I mean specifically on your vehicle). Is it the sonar kind that just beeps when you get close to something? Usually those are routed to their own little speaker. If yours is integrated in any way in to your stock OEM system you'll have to figure out how to make the correct electrical connections yourself, or pay a pretty good installer to do it for you; you aren't going to find an adapter that'll do it. In other words, it isn't going to be worth the trouble.
The Z supports a back-up camera, you know. Probably cheaper to just buy and install that and as a bonus it's better than a back up sensor anyway.
Posted May 27, 2010 · 00:16 UTC#4
Yeah, it's the sonar kind and it works through the oem unit, quieting the music and beeping through the car's speakers. I know about the back-up cam, I just was hoping to avoid the trouble of wiring, drilling a hole, etc.
Posted May 27, 2010 · 21:27 UTC#5
Backup cam would probably be easier. Anyway, you have 3 (maybe two) wires to look for.
First, find out where the sonar controller is. I have no idea in the Navigator; in the Nissan Titan it's in the lower driver dash.
Next determine if it's really going through the OEM speakers, or if it has it's own speaker/beeper and simply sends a mute command to the actual OEM stereo. I strongly suspect it's the latter if there's even a separate unit at all. They could have integrated the Sonar unit right in to the OEM HU itself in which case you are out of luck.
Probably be easier to run a backup cam :) I bet even if there was a way to make it work you'll spend more time wiring and screwing around with that then you will a camera.
Posted May 28, 2010 · 15:51 UTC#6
Ok, I think you're probably right about it being easier to do a cam. Thanks for the help!
