Ok, tried a search but came up dry. I have a 110bt and I have been having weird audio level issues. I started with the hu and a jl g6600 amp. Well after about a week with the setup, the right front channel would shoot up in volume and other channels went quiet and it stayed that way. Ok thought the amp was bad, so I worked with my installer and we changed it out for a JL HD900. Sweet amp, and every thing has been awsome. Until today. Now one week after we changed amps, the front left channel goes up in volume and then the rest go really quiet. After a bit of time everything returns to normal, so better than the last amp, but not what it should be.
I was wondering if anyone else has seen this problem. The only constant in all of this is the same z110bt hu is in the dash. Could the hu be busted? My installer is skeptical two amps go bad especially since they work perfectly for a week or two before the issues appear. The installer has checked the speakers for shorts and other isssues and found nothing.(they spent about 8 hours on this). Any help appreciated.
