I ran into the same issue. The X920Bt only has a blue and white remote wire. I have a 09 STI that has a powered antenna and I also have some subs and an amp.
According to the manual, you cant have to much sucking off that blue/white wire. Somewhere in the manual, it says something about 300 max. I dont remember off hand what exactly it was, but i think its mentioned on page 15 of the manual.
At any rate, my radio reception SUCKS! Ive tired the b/w wire off the X920Bt to my powered antenna ONLY and while it works, my reception has a lot of static.
Running my amp off the X920Bt Blue and white wire, WITH the powered antenna works the same for me too. FM reception still sucks!
I even tired running my powered antenna off a 12v acc wire and it still sucks!
Why does FM reception suck so bad on this deck? I had a D3 installed in this car before and it worked just as good as my stock radio reception.
Dam!
