Unable to enter system settings
By iggy · May 28, 2010in Problems/Troubleshooting💬 11 posts👁️ 1,420 views
Posted May 28, 2010 · 10:06 UTC#1
Hi,
I am a newbie to AVIC, just got my F700BT that I bought used from eBay. The unit came with the power cord only.
Wanted to check the unit so I connected the red and yellow wire to +12V on my power supply, the black wire to ground - unit starts normally, but when I enter the Settings menu, I can only change AV Settings and AV Sound, but can not get into System and Navigation settings as they are kind of grey, with no possibility to enter.
Any idea how to handle it? Does it have something to do with the bypass?
Thanks,
iggy
Posted May 28, 2010 · 11:01 UTC#2
Yes, time to read up on that in one of the fantastic threads folks have helped create.
Posted May 29, 2010 · 12:33 UTC#3
OK I will check.
iggy
Posted May 31, 2010 · 15:06 UTC#4
Works fine, thanks!
iggy
Posted Jun 12, 2010 · 22:46 UTC#5
hello. i am having the same issue. please help and advice what you did to fix this.
thanks
Posted Jun 13, 2010 · 00:41 UTC#6
thanks
They read the existing posts and FAQs in regards to bypass, if you read them it would answer your questions too, no one else will read them for you.
Posted Jun 13, 2010 · 15:27 UTC#7
i read them but didnt find the right thing to do. can you please send me the link to the right link.
Posted Jun 13, 2010 · 16:23 UTC#8
Honestly? the bypass threads are VERY clear and easy to understand, if you're not able to follow them, then maybe you should not be attempting to perform the bypass.
Posted Jun 13, 2010 · 16:56 UTC#9
it doesnt seem to be the bypass issue, i think the firmware is corrupted. where can i find the winceimg.csk file? is it inside the 3.1 firmware?
Posted Jun 13, 2010 · 16:57 UTC#10
Well if that's the case then your issue has nothing to do with the thread you're posting it to and you do not have the same issue that the OP had, you may be better off starting a new thread.
Posted Jun 17, 2010 · 07:10 UTC#11
for me it was the bypass issue, after tweaking a little bit with the wires the two disabled settings became enabled.
iggy
