I have a 2005 mustang and I have install a X920BT with a PAC C2R-FRD1 adapter, since I have a shaker 500 I have used the Blue/white wire to connect to the "Amp turn on" wire of he PAC.
Now, when I start the car I sometime loud "Pop" in the subs, what is bizzare is that it's not doing it if I go from off to "ACC" or to "Run"(but not starting the car), I can go from "Off" to all these position and there's no POP. But when I Start the car (cranking the starter) sometimes I have a loud "POP".
I know the Ford amps requires 5V amp turn on voltage. According to the documentation the radio supplies 12V on the Blue/white wire but the PACmodule is supposed to bring this voltage down to 5V according to the documentation
Any idea what could cause that "POP" ? It's only when I start.
Thanks,
