Considering upgrading from Z3.. wire harness compatability?
By gmschiller · May 31, 2010in General💬 4 posts👁️ 945 views
Posted May 31, 2010 · 20:03 UTC#1
I'm considering upgrading from the AVIC Z3 to the Z110BT (might even buy 2). My question is about the wire harness. Are they easily interchangeable, or will I have to install a new harness?
Posted May 31, 2010 · 20:44 UTC#2
You will have to install the new harnesses.
Posted May 31, 2010 · 21:29 UTC#3
grrr, ok then. Well, at least everything else is already installed. Should be able to use the same GPS receiver and vehicle sensing wire I hope.
Posted May 31, 2010 · 21:39 UTC#4
Not sure what the Z3 GPS plug looks like but if they are different then it should be a simple swap of the plug adapter. I know from D3 to z110bt thats what I did.
