I put some photos here and the material I used:
For materials I used:
Two trims car stereos.
I removed a radiocd and I took the front with pull-out, and I used only the back bone without the removable, so I cut to the flush, then I have been hitting the pier and the connector so I removed parezaca removable.
Glue.
Plastic stick to the trim, in my case I took the box of a video tape.
And self-adhesive sheet of black plastic to cover everything and be better.
Fridge magnet (only 3cm in length and width that give the frame of the screen) and a small sheet of thin sheet metal and measures about 3cm. it is stuck behind the cover, well it should be borne in mind that the screen has o'5cm projecting ahead of the frame, so that between the magnet.
And finally I put in the bottom to conceal more my little Fiat logo, you can also use what you want.
