GPS not working
By Din · Jun 02, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,266 views
Posted Jun 02, 2010 · 00:01 UTC#1
Does the speed sensor need to be connected in order for the navigation to work? The navi on my D3 does know where I am at, doesnt move when i drive.. What all needs to be connected in order for this to work? Thanks.
Posted Jun 02, 2010 · 00:07 UTC#2
No, the GPS antenna is all you need for the GPS system to triangulate your location.
Posted Jun 02, 2010 · 14:36 UTC#3
hmm ok. i do have the GPS antenna hooked up and it still does not know where i am.. Is there some kind of setting i need to put it on to find where I am? Any ideas?
Posted Jun 14, 2010 · 05:56 UTC#4
Try hard resetting the unit. If you got it used it would probably need a reset and a new home location set. If it's not that then your antenna could be broken.
