Upgrade from D3 Question
By jleilich · Jun 02, 2010in General💬 5 posts👁️ 872 views
Posted Jun 02, 2010 · 16:42 UTC#1
I have a D3 installed in my 06 Charger with all steering wheel controls and using factory amp.
Can I upgrade to a Z series without to much hassle? Are the plug ins on the back the same or similar enough that I would maybe just have to get a new harness?
thanks
Posted Jun 02, 2010 · 17:32 UTC#2
i've got a magnum and have kept factory amp and steering wheel controls. if you are using the pch chy4 harness and pc-swi-ps than should be able to just cut the connections and attach them again to new pioneer harness
Posted Jun 02, 2010 · 19:57 UTC#3
It depends on which Z series you plan on getting.
Posted Jun 03, 2010 · 02:07 UTC#4
scharnhorst Yes I am using those harnesses as well that's what I was hoping.
VBLUE42 , can you elaborate a bit? Which will or wont work?
Posted Jun 03, 2010 · 02:14 UTC#5
The power harness from the D3 is transferable to the Z110/120 series but the RCA harness is not. I have no knowledge as to weather they are to the previous Z series.
