So i took out my radio to install a new A/C unit in my car and try and clean up the cables back there.
I have two boxes on the IP-BUS (Bluetooth and XM). After putting everything back together I have NO audio over either box connected over the IP-BUS. I have audio over iPod, FM/AM and Navi/DVD. The IP-BUS cables go from the D3 > Bluetooth IP-BUS IN. And then Bluetooth IP-BUS OUT > XM IP-BUS IN.
FYI it worked correctly before I went in there to "clean up" the wires.
Any idea what I should be looking for when I take it apart this weekend or if my setup is not correct?
