Nav voice vloume differs with different AV source?
By andis20 · Jun 05, 2010in Problems/Troubleshooting💬 2 posts👁️ 622 views
Posted Jun 05, 2010 · 04:10 UTC#1
How do I adjust the nav voice so that it's actually audible when i'm listening to music from different AV source? When i using SD for audio, the nav voice is quite loud, consistent with the master volume. But when the AV source is either CD or radio, i can hardly hear the nav voice guidance - eg. main volume would be on 50 and can't even hear voice guidance.
Have tried adjust in the nav sound settings while either CD or radio is playing and makes no difference - it seems the nav sound setting is set regardless of current AV source.
Can anyone shed some light? Model is F910BT
Posted Jul 05, 2010 · 18:35 UTC#2
Hi
I had a similar problem with my F900BT, when it was connected using the RCA connectors I had to set the volume to about 45/50 to get decent sound level but the sat nav voice and the phone volume was too low. I rewired using the speaker outputs and all volumes worked perfectly
Hope this helps
Mark
