Cut USB Cable
By shomed · Jun 06, 2010in Problems/Troubleshooting💬 5 posts👁️ 627 views
Posted Jun 06, 2010 · 01:50 UTC#1
I just received my F700BT unit back from repair for a boot loop problem. I could not get the usb cable to work and now I have found it is because it is actually "cut". Is there a way to replace the internal usb cable?
Posted Jun 06, 2010 · 01:56 UTC#2
Just do a solder job on it with a new cable or the same one.
Posted Jun 06, 2010 · 07:58 UTC#3
I did cut the cable fully and there are four wires, black, red, green and white. There is also some plastic filament, is this to make the wire more stable, the four colored wires are pretty thin, or do they serve a purpose? Never did this before either is there a certain solder I should use for this kind of cable? thanks for your help :)
Posted Jun 06, 2010 · 08:05 UTC#4
Yeah USB uses 4 cables. Just use regular solder on it.
Posted Jun 08, 2010 · 00:31 UTC#5
Thank you so much for your help, did the solder job, patched it really well and it works like a charm.
