Install from AVIC-Z2 to Z110BT
By november84 · Jun 07, 2010in General💬 3 posts👁️ 785 views
Posted Jun 07, 2010 · 19:22 UTC#1
Hello,
I didn't find any info searching the forums to this question, so I figured I should post.
I currently have an AVIC-Z2 w/ a PAC steering wheel control and Blue tooth. The unit is connected to a 4-channel amp (RCA) and a sub amp (RCA). I'm looking to replace the unit with an AVIC Z110BT (upgrading later to a Z120BT via software). My question has to do with the physical installation. Do the connectors/harness match between the units? Are the microphone and GPS antenna interchangeable? Thanks!
Frank
Currently installed in 20001 Buick Regal GS
Posted Jun 07, 2010 · 20:13 UTC#2
Hello,
Frank
The Connector/harnesses are not the same.... Luckily you don't have any of the speaker wires to cut and reconnect(just RCA's...VSS...reverse....powers...ground)
I reused my GPS antenna and mic from my previous Z2/3, with no problems at all...
Posted Jun 07, 2010 · 20:14 UTC#3
Also.... if you have enough steering wheel buttons...and you want full control(voice command), then you will need to update your PAC SWI-PS to version 1.6.8 or better....
