Ladies/Gents,
I purchased the 3.0 upgrade from Pioneer for my F900BT. I did the install following the manual meticulously. Everything seemed to go fine. No errors, nothing weird and at the time I was dually impressed. When it was complete, I restarted my nav for the first time with the 3.0 upgrade installed and the "System startup in progress, please wait.." banner stayed on the screen. I couldn't get into most of the menus and there was nothing I could do. Whenever I would press the Map button, it would seem to freeze up. My issue lacked the constant rebooting problem, but I'm sure my fix will correct that too. I knew I had to reinstall the update but needed to figure out how as the update won't run a second time. It just says it's already updated.
I have been in the IT field for 11 years now and have worked on Windows PCs/Servers/Devices for as long as I can remember so this is why I think it will fix most issues like this.
Here is what I did:
1. If you have purchased the 3.0 upgrade or "own" it somehow, copy the Windows CE BIN and CKS files to the root of a freshly FAT32 formatted SD card
2. Go into "Service Mode". If you dont know how, search it cos there are threads describing the process in this forum.
3. Selected "FORMAT and intall Windows CE from SD/MMC (I know for sure it's the 1st option in the list in the service mode dialogue)
4. After the install completes, remove the SD card with the Windows CE BIN and CKS, reboot the unit and quickly insert the 1st SD card that you got from Pioneer (or whichever one you own that has the 3.0 software on it)
5.The update should start like it normally did the first time. Follow the process like you did before and it should work. I know from experience that when in doubt with a Windows machine, reinstall!!!!
Any questions or further info needed, let me know.
Neo.
