I have to say here is a link to a youtube video where you can kinda here the problem
Humming noise
well which speakers is the hum coming out of? have you tried using different RCA outputs? Using different combinations
Thanks for the quick reply any way ya i have tried one i have tried 4 it comes out of any one i hook an rca into and its not so much a hum but the sound of power maybe?. No clue what it is maybe i need a filter?
Ok I pulled the deck out 2 inches it went away now I got to figure if I need to keep all those wires extreamly far away from the deck lol
Pulling the deck out seemed to fix it upon closer attention going closer towards the speaker it only softend the hum/buzzing noise im still proplexed .
Sorry to bring this old thing back up.. But im having the same issuse. I have tried everyting from check RCA, Ground loop, Re-grounding.. Anyone can shine some light to this!?
You might want to check the resistance on each cable between the center pin and the outer rim on each RCA plug. I am guessing one or more has bad insulation. Be sure to unplug the connector from the head unit before you test the plugs.
