How do you switch from day to night mode automatically? I tried doing it manually but it only stays on the bright day setting...
Posted Jun 13, 2010 · 09:01 UTC#1
Setting the map color change
between day and night
To improve the visibility of the map during the
evening, you can set the timing for changing
the combination of the map color.
1 Display the “Map” screen.
2 Touch [Day/Night Display].
Each time you touch the key changes that setting.
! [Automatic] (default):
You can change the colors of a map between
daytime and nighttime according to
whether the vehicle lights are On or Off.
! [Day]:
The map is always displayed with daytime
colors.
p To use this function with [Automatic], the
Orange/white lead of the navigation system
must be connected correctly.
Yes, I already tried this "automatic" and it only stays "day" never changes...
Is the orange wire connected to the illumination wire?
