Avic f900bt probleM
By dman45069 · Jun 13, 2010in Problems/Troubleshooting💬 2 posts👁️ 816 views
Posted Jun 13, 2010 · 16:07 UTC#1
This is my first post and day on thus site!!! Woohoo!!
My radio quit the other day. I had it installed and the mute and light green wire were attched to the ground wire. I disconnected those two. The radio turns on but only goes to the splash screen. It will reboot and do the same o er and over. I tried to use the sd card to reset it to 2.0(which it always has been) but it will not recognize the card. I miss my radio!! Thank you in advance for any help
Posted Jun 17, 2010 · 15:07 UTC#2
You should upgrade to 3.0 software/maps and at the same time you will be rid of the rebooting problem. You can re-ground the wires so that all functions will be available. Try searching for "reebot fix 3.0 install".
