D3 stopped calculating route
By mansory · Jun 14, 2010in Problems/Troubleshooting💬 4 posts👁️ 1,445 views
Posted Jun 14, 2010 · 03:36 UTC#1
I tried once before and it worked perfectly, I'm using a burned disc.
All of the sudden it stopped and won't calculate anymore. Gives me "Route calculation was not possible"...I can even hear the drive power down. I know it's not the disc drive because DVDs and the like work perfectly. Could it be the disc?
Posted Jun 14, 2010 · 05:47 UTC#2
So it tells you where you are on the map when it's not calculating a route? If not then it could be a faulty antenna.
Posted Jul 09, 2010 · 07:11 UTC#3
My navigation just started doing the same exact thing...really weird!??!
Posted Dec 01, 2010 · 03:14 UTC#4
Anyone solve this issue? The drive seems to work, I can view saved addresses, etc. Just when I try to map somewhere it presents me with the exact same message.
