Hello, i think then i read, everithing abaut changing maps.
In first time i changed FM from 2.0 to the 3.2 and in new FM are maps 2.0600 but i am from Czech Republic and in FM 3.1 is map 10.2008 and it is very old.
A searched many maps IGO 8.3 and 8.0 czech republic (TeleAtlas Ceda and different) Every maps are news (2009/20010) has same names and in different navigation then using Igo 8.3 are function but not in F900.
When i´m changing maps in flash disc, their isnt in list vith maps and on the screen is onli red bolt and poi but not map. when im changing back old map is everithing function and map is in list.
A searched teme map for australia and then enybody write so ehen i can chang diferent map i need cracked Ezrider and licens. Both i downloaded but when i added licens and changed ezrider. Navigation doesn´t start (funkction was only audio, no navigation and on streen was "pleas wait ..starting system") when i give back old ezrider is function old maps.
Can i help me enybody ??????
Is enithing diferent in europe version then USA vesrsion IGO ? Or where is problem ??? Diferent ezrider for europe ? or bad maps ? Bad licens ? i don know :/
Same problem was when i changed schemes (downloaded from this web)
Thank you (pleas write manual no diferent topicss) I read everithing here
