Looking for some help with the N2 bypass. Read quite a bit and tried it for myself, thought I would share and ask you all what you thought.
At first I tried the solder method, but it was just too difficult to fit the
solder in there and get it just right. So I looked to the forums for an
easier method.
After reading the forums I thought I would give it a second shot. I easily
found the sticker, got a circuit pen, and drew a line between the jumpers.
Filled it up pretty well no doubt their is metal connecting the two points.
Start up the unit, find the reset button, everything works - except the
bypass. Start the car, drive a bit there is nothing different. No using navi
while driving.
So I bring the unit back in. Clean it up with a thumbtack very gently. Use a
wet Q-tip to get some metal shrud out. Scrape around the jumpers as best I
could.
Put the unit back in the car, still works (this is with no circuit anymore)
Bring the unit back in once more. Once again apply a liberal amount of
circuit metal. Let the unit sit about ten minutes. Use a blow dryer for
about 20 seconds. Install the unit back in my car, everything works - except
the bypass.
Do you have any idea why the bypass does not work on my unit, and if there
is anything I can do to get it to work? The avic means nothing to me if I
can't use it while driving.
Thanks.
EDIT: Yes, the parking break is grounded.
