A few questions
By madmanfrommars · Dec 16, 2006in General💬 18 posts👁️ 3,922 views
Posted Dec 16, 2006 · 17:05 UTC#1
First, how do I display the time on the small display when the screen is closed?
Second, is there a way for me to search for a specific POI by distance? For example, if I wanted to find the closest starbucks to my current position, or closest washington mutual etc...
Third, I don't think the place I got my n3 installed at hooked up the connection to switch the avic into night mode when I turn the headlights on. I can't make it back there for another week or two but I'll have them take care if it. In the meantime, how come when I switch in the map display options between day mode and night mode nothing happens? Its always in day mode for me.
Thanks.
Posted Dec 16, 2006 · 18:17 UTC#2
for the poi question, you simply select the name of the place, then it will ask what city and so forth, on the upper right side there is a a-z and a dist icon, which a-z is alphabetical city names, and dist is the distance.
Posted Dec 21, 2006 · 02:46 UTC#3
Nobody can answer any of the rest of my questions?
Posted Dec 21, 2006 · 02:56 UTC#4
1. When the screen is retracted, hit the second button from the right on the closed portion of the screen. (see button # 5 in illustation picture at end of post)
2. Already answered.
3. Sorry, didnt even know the Nx series had a night mode LOL. Mine just dims slightly automatically when the sensor built into the unit senses darkness (as to not blind you at night!) :)
Posted Dec 21, 2006 · 12:16 UTC#5
Paisan: That button for me is "Band", not "PGM", and it doesn't cause the time to be displayed.
Posted Dec 21, 2006 · 22:59 UTC#6
Button # 5, not button # 2, will display the time on the outside lcd screen. Button # 5 is second button from the right. This is the button that, when the screen is fully upright, temporarily lowers the screen for 10 seconds. When the screen is fully retracted inside, this same button will show you the time, or if pressed again, back to the channel name/station, depending on which source you are using at the time.
Posted Dec 22, 2006 · 02:41 UTC#7
Yeah I actually figured that out when I was driving before, thanks.
I was way too tired when I read that before, I thought you said second button from the left.
Posted Dec 22, 2006 · 11:51 UTC#8
No problem. enjoy! :)
Posted Dec 24, 2006 · 16:27 UTC#9
Okay so I talked to the shop that installed my car. They said that my car does not have a dimmer in it, so they weren't able to hook up the illumination connection normally. They said if I really wanted it then they'd have to hook up a relay to the headlights, and it would cost more money to do and possibly void my warranty.
Is this true?
And if so, how do I manually put this thing into night mode?
Posted Dec 25, 2006 · 02:55 UTC#10
which shop, that doesnt sound right
Posted Dec 26, 2006 · 03:16 UTC#11
This shop called audio planet. They always seemed to know what they were doing...
Wheres ctrlyver or whatever when I need him?
Posted Dec 26, 2006 · 16:34 UTC#12
05 Jeep Liberty - orange/brown (dimmer) + radio harness
that is according to directechs so it seems it does have a dimmer which makes sense.
Posted Dec 27, 2006 · 06:45 UTC#13
Okay thanks. I'm going to go down there in person tomorrow and discuss it.
Do you have the link of where you found that info?
Posted Dec 27, 2006 · 15:31 UTC#14
Yeah so I was nearby today and I stopped in and talked to them. The guy there said it should have been done, and I made an appointment.
They probably got lazy and figured I'd never notice.
Posted Jan 08, 2007 · 15:38 UTC#15
Well they just hooked it up. Everything works fine.
I think the night mode looks really cool. Especially in drivers view where it switches from the clouds to the stars.
Glad I pushed the issue with them.
Posted Jan 08, 2007 · 20:39 UTC#16
Okay I'm just gonna keep attaching on to this thread.
My question now: Sometimes it seems that the GPS gets completely lost and I end up on a different road them I actually am. Is there a way to tell the nav to reset itself and redetermine my location?
Posted Jan 17, 2007 · 01:53 UTC#17
bump...
Posted Jan 17, 2007 · 02:04 UTC#18
No but under your Nav menu, there is a button Modify Current Location, then you can tap on the map where you really are.
