Getting the Z1 installed on Tuesday
By URDONE · Dec 16, 2006in General💬 8 posts👁️ 1,192 views
Posted Dec 16, 2006 · 23:35 UTC#1
I am getting a Z1 unit installed on Tuesday on my 2003 GS 300. I will also be getting the Ipod adaptor, blue tooth, and the rearview camera. Is there anything I really need to know before then? I am reading about you guys getting these Ducatiboy bypasses, do I need one? Does this bypass do the same thing that the headlight flicker trick will do? What should I look out for? Thanks :D
Posted Dec 16, 2006 · 23:51 UTC#2
Yes, they were very popular.
do I need one?
Only if your Z1 was made before Mid July 06, if it was made since then you only need to ground 2 wire.
Yes, my circuit told the Z1 that you flashed the headlights automatically every time you started the car, so you didn't have to.
If you have a newer one, you can just do the 07/06 bypass listed here:
http://www.sminntech.com/z1flash.html
Posted Dec 17, 2006 · 06:10 UTC#3
get the bypass so you can watch DVD's :D
Posted Dec 17, 2006 · 18:48 UTC#4
I should be able to watch DVDs with the headlight flicker trick correct? Or am I getting this trick confused with a different function?
Posted Dec 17, 2006 · 19:48 UTC#5
You can if your Z1 was made before Mid July, if it was made after you need to ground 2 wires to do the same thing.
Posted Dec 18, 2006 · 00:27 UTC#6
Gotcha. How can I tell when it was made? Hopefully the guys doing my install are willing to do the extra step for me.
Posted Dec 18, 2006 · 00:35 UTC#7
The date, Month and Year (so far all 06's), is printed on stickers on the box, on the unit itself and I believe on the warranty card.
Posted Dec 20, 2006 · 12:35 UTC#8
Well the headlight flicker didn't work. So I need to do the 06/07 bypass. I got the wrong ipod adaptor, so I have to take my car back to the shop to get that installed. When I take it back, I am going to take the write up on the bypass and have the install guy run me through it.
