Hi,
I don't think the external auxiliary audio input CD-RB20 is being detected by the AVIC. I hooked it up and it didn't seem to come up in the sources or the AV Source Settings menu. (The Sirius module did come up automatically in the sources.)
I ran out of time to start troubleshooting, so I will check it out carefully when I get home. Here is what I know:
1. Power and Ground are good. They are the same power and ground that the Satellite Module is using. If one had a bad connection then they both would. I am certain that power and ground are fine. I used the Battery+ line. I believe the Battery + Output line is meant to power another device such as a multi-cd changer. This "Battery + Output" line is not hooked up to anything.
2. The Satellite module is plugged into the headunit first. The CD-RB20 Aux Input is connected to the pass-through of the Satellite module. The Sirius Satellite works. I get station 184 just fine. The Satellite Source was auto detected and showed up automatically in my Sources list.
3. When I get home, I will try plugging the CD-RB20 Aux input directly into the head unit instead of the pass through. I also did not have anything plugged into the RCA jack. This time I will have my MP3 player hooked up playing music the whole time on a medium volume.
4. I believe my AV2 Input is assigned to "Ext", which I think is correct according to page 19 of the installation manual. I will double check this though to make sure this is how it is set.
5. AV1 Input is assigned to iPod.
Has anyone else hooked up the CD-RB20 input to this stereo before?
Edit: I see on page 146 of the Operation Manual that I should have either EXT1 or EXT2 showing up on sources.
I see on Page 168 and 169 where it talks about Ext1 and Ext2, but it is confusing. The CD-RB20 is connected via the IP-Bus. It says "EXT: Pioneer external unit connected with the RCA video cable". I don't have an RCA video cable with this input, just using it as an auxiliary audio source.
Shouldn't the CD-RB20 be automatically detected?
