So I'm trying to insall my X920BT in a 2k5 Jeep GC (no nav or boston acoustics) and the thing won't power up. I verified that the stock deck still powers up when I plug it back in, but the 920 won't boot at all - no fans, nada. I checked the 10 amp fuse on the back and it seems to be fine. I cracked open the 920's case to look for blown capacitors and they all look fine too. The wiring harness I got was the soche? It has two yellow (power) and two blacn (ground) wires coming from it.
My questions:
1) will the 12vdc leads coming from my factory harness suffice to power the 920BT since it requires 14.4vdc?
2) Will i need to ground to the chasis rather than using the factory harness ground wires?
3) have these wiring harnesses been known to be bad?
4) Is it potentially the head unit - how do i test if it is?
